Drilling For stud pattern....
https://forums.aussieveedubbers.com/threads/77839/drilling-for-stud-pattern
learjet79 ·
Where in melb can i get my rotters and rear drums drilled for eitheer 4 or 5 stud pattern, 4x100 or 5x114.3 prefer 4x100???
Send eum up to Sydney
polak ·
vw54 wrote:Send eum up to Sydney
hahaha! thats hardly helpful Birchall! 😂😂
amazeer ·
Any engineering machine shop should be able to do that for you. Its a first or 2nd year aprentice job.
greedy53 ·
i had a plate of steel made years ago, that is bolted onto a disc or drum using the wheel bolts and has guide holes for drilling 4 x 100 holes and i use a drill that come with wheel studs very cool, works great didn't cost a million nearly
grumble ·
Be careful redrilling standard rotors as they are strengthened at the original holes and are thinner between.
learjet79 ·
arn't spacers ilegal?????
1500S ·
learjet79 wrote:arn't spacers ilegal?????
I think you will find that Greedy53 used the plate as a drilling jig, not a spacer.
DH
i spin mine in a lathe to get perfectly true PCD
4x100 fits nicely inside the stock 4x130 and picks up the original webbing well if u slightly offset the holes abit so theres plenty of meat between them
hellbugged ·
learjet79 wrote:5x114.3
is that ford or commodore pattern.....may have four wheel discs for you if so
ford/toyota/nissan etc
holden and BMW are bout the only 5x120 mainstreamers
BUGBOY ·
I can machine them for you, or supply blank rotor and hubs and machine them also.
