Does someone have intstructions or pictures for a swingaxle?
Trying to figure out what needs to be undone at axle ends 馃お
trickysimon 路
Aussieveedubbers 路 Tech Talk
https://forums.aussieveedubbers.com/threads/77841/remove-gearbox
trickysimon 路
trickysimon 路
dpradford 路
trickysimon 路
Joel 路
add to that d/c clutch cable, starter wiring and reverse light wiring 馃槈trickysimon wrote:Ok this might not be the easiest way but this is what I did:
1. Undo bolt at bottom of shock
2. Undo two? bolts holding spring plate to axle tube. You should be able to pull axle tube backwards out off spring plate now
3.Take off the axle nut so you can get the drum off
4. Push out tab holding brake line to axle tube and unbolt brake line from back of drum brake. (I did not need to undo handbrake)
5. Undo the four nuts holding the backing plate to the axle tube and pull backing plate away from tube (Have a rag handy, oil will pour out here)
6. Repeat for opposite side
7. Loosen off two bolts holding in front mount and undo the big bolts holding the rear gearbox cradle in
8. Go in under back seat and unscrew inspection plate
9. Cut tie wire and unscrew the square looking bolt. This should disconnect shift linkage
trickysimon 路
dpradford 路
trickysimon 路
