Aussieveedubbers · Bugs
Speed Sensor for 74 Std 1300 Beetle
https://forums.aussieveedubbers.com/threads/77967/speed-sensor-for-74-std-1300-beetle
Nathan ·
Hi guys I have a 74 1300 Standard beetle that I'm restoring/doing up and I've decided I want to fit an aftermarket Speedo into it (Speco) but I need a speed sensor for it and was wondering if anyone from here might be able to help me as to where I could get one etc?
Nathan.
grumble ·
Try one of the VDO instrument repair shops.
blutopless2 ·
where are you located?
Nathan ·
I'm in Newcastle.
Tea Gardens Marine & Hire can help...
grumble ·
Naamiss in Carrington.These guys do a lot of my gauge & speedo repairs.
Nathan ·
grumble wrote:Naamiss in Carrington.These guys do a lot of my gauge & speedo repairs.
Thanks for the suggestion Grumble.
After looking at their website they look like they are the go to guys for this problem.
I'll give a buzz tomorrow or monday and I'll let you guys know the outcome.
Nathan.
beetleboyjeff ·
I have a couple of guages that I need looking at too. This certainly looks like the place. Took a while to find their website though - it is actually spelt Namiiss.
grumble ·
Sorry mate a couple of beers adds an extra a and drops i's .Whatever they are still bloody good. Les
Nathan ·
http://www.namiiss.com.au/
Nathan ·
Hey guys sorry for the delay in getting back with the info I got from Namiis, I was working the last 2 weeks straight.
I went to them with my new speedo and asked the questions and in response they suggested using a GPS Speed Sender Unit with use's a GPS signal recived via an antenna placed in an unnoticable spot and goes into a little unit mounted under or behind the dash which in turn sends out pulses to the speedo giving you your speed. After reading the instructions they appear to be easy enough to setup and calibrate.
They are abit expensive but well worth the money in the long run seeing as adapters only last a couple of years at the best and they have had nothing but great comments on these GPS units.
I'll let you all know how this works out over the next month or two when I install everything.
Nathan.
