that's a great car you have there. plug in some antilag and it's go like a WRcar. 馃槒
seagull 路
Thanks for the write up Jak , nice work
ricola 路
Aren't you tempted to up the boost a little bit?
Would love to see some pics of your exhaust mods too...
Craig Torrens 路
gotta be happy with that 馃憤
Flintstones 路
Sweet!
seagull 路
Craig Torrens wrote:gotta be happy with that 馃憤
what , go to the doctor ! are you ok man , gee may be , just may be he is comming to the dark side 馃シ
squizy 路
Fatherhood has mellowed Craigie. 馃檪
Nice read up Jak. That's certainly some reliability you have there. 馃憤
1303Steve 路
Has Craig joined the clergy
seagull 路
jak, what turbo are you running TD05 18G ?
Flintstones 路
I would have thought you'd rebuild it when you did your engine?
S'pose you'll be the first to know LoL 馃榿
D
reub 路
Great read Jak - awesome in fact. Huge congratulations to your success with your conversion.
I saw on ebay you can get new TD05 20G turbos for $600 or so too..
Again, congrats, and thanks for sharing your success with us all.馃憤
seagull 路
Hi Jak , Thats quite a lot of ks but with stock boost it will last for a long time yet .
I am with Reub , should you rebuild it go for the TD05 20G , you will love it 馃檪
reub 路
seagull wrote:Hi Jak , Thats quite a lot of ks but with stock boost it will last for a long time yet .
Better then a VF23 or VF22 hey??
GTMac 路
Still going strong Jak, and you dont drive it like a pussy which is good as well 馃槀
So what is the 20G turbo, I run a TD05 but no idea what it is. Why would Jak for this over the 22 or 23 VF series?
seagull 路
GTMac wrote:Still going strong Jak, and you dont drive it like a pussy which is good as well 馃槀
I am thinking Jak has a low mount intake like the RS turbo
The TD05 20G , would be a direct fit to his set up
The TD05 20G , imo is a more drivableless lag than a 22/ 23 & would last 10 x longer than a VF22 as we all know when you boost them they go bang.
I have a TD05 16 G , its off an Evo , look that up on the web it may get you thinking
1303Steve 路
Hi Neil
Sorry to hijack your post Jak, do the VF 23 suffer the same fate as VF22s?
seagull 路
Hi all , The evo turbo Td0516 G has larger wheels than the WRX unit & the flanges are od looking 馃檪
This is my Evo turbo
GTMac 路
Neil, so would my 94 WRX engine likely be running a TD05-16G? So are you saying for some reason the Evo and WRX turbos are different even though both being 16G's? Does the Evo turbo still bolt up to an EJ20?
Doing engine upgrades early next year so just looking into turbo options.
seagull 路
GTMac wrote:Neil, so would my 94 WRX engine likely be running a TD05-16G? So are you saying for some reason the Evo and WRX turbos are different even though both being 16G's? Does the Evo turbo still bolt up to an EJ20?
Hi mate , I can not tell you 100% as some had the Td04 turbo
To let you know , if you see a clasic wrx say 1994 JDM half cut with the front A arms in steel , it will more than likely have a TD04 turbo fitted
If you find a clasic wrx say 1994 with ally front A arms , it will on most cases have a TD05 xx turbo fitted . These are a better motor
Anther tip is to date the motor & remove the oil cap and look at the dates.
Yes that is correct the Evo has different wheel sizes than WRX all though the same numbers.
no the evo turbo has different flanges, as can be seen above
VWCOOL 路
yeah good stuff Jak, plenty of stocko Subies out there with 250+Kkm on them... they are almost as reliable as a VW engine!!
seagull 路
Jak Rizzo wrote:I always thought that the VF34 would be my choice for an upgrade, they seem to have a really good spread of power & seem to be the choice of turbo from most of the wrx boys as the next step up from standard.
regards
Jak
I have the the new Vf34 fitted to my Gen 2 liberty AKA GTB/ V3 STI , hee heee I even have a 6 speed in the old girl 馃檪
