flogged out rear wheel bearing covers?
https://forums.aussieveedubbers.com/threads/78045/flogged-out-rear-wheel-bearing-covers
pete wood ·
Just pulled the rear wheel bearings on one side to find that the outer bearing seems ok, but is moving a little in the cover. What's the fix for this? Can I just thin (by sanding with wet and dry) the cover a little so it gets a better hold on the bearing?
Klaus ·
still can buy new ones. empi? or latest rage.
pete wood wrote:Just pulled the rear wheel bearings on one side to find that the outer bearing seems ok, but is moving a little in the cover. What's the fix for this? Can I just thin (by sanding with wet and dry) the cover a little so it gets a better hold on the bearing?
is this an IRS rear axle??
are You talking about the spacer?? between the bearings?
bearing Housing??
I don't think wet & dry will thin steel...
more like a file... very carefully...
any pics??
