clutch has done something wierd??
https://forums.aussieveedubbers.com/threads/78049/clutch-has-done-something-wierd
Anthiron ·
So i was driving around as normal the other day, almost pulling into my driveway. went to change into 1st gear and pushed in the clutch. heard a funny click sound and pedal went down almost to the floor before i felt a spongy bit of pressure. Got it into first a putted in and then had a fiddle.
it felt like a few strands had snapped on the cable as it went spongy and there was far too much travel, the way it was the clutch didnt fully engage when depressed.
So i pulled out the old cable but it was perfect. not a problem with it that i could see. so i put it all back together and adjusted it tighter.
it now engages fine, and doesnt seem to slip but it feels very light and spongy.
before this happend it was very firm, almost heavy. i liked it that way.
thought it might have been the return spring on the fork arm but that looks fine too.
any ideas?
oh and the clutch is only brand new, professionally fitted a few months ago.
Nicko
ancientbugger ·
Could the cable have been fitted incorrectly the first time and just slipped into place now. Where the cable connects up to the pedal hook. I've managed it in the past!! You haven't noticed any difference with the angle of the clutch lever at the gearbox I take it.
Anthiron ·
im not sure about the angle of the clutch fork arm barry as i dont remember where it sat before. i suppose its possible but it lasted a few months the way it was i would be surprised if that was it.
its got me stumped.
Klaus ·
the steel clutch tube in the tunnel has broken free, your going to have to cut 2 inspection holes into the tunnel on the pass side to access it to begin the fun job of rewelding it to its supports. someone else may have the spots where the supports are located (havent done a beetle cable repair for a while ) .
look at the bowden tube and see if its flat ie no preload , while your under there look for the steel pipe and see if it moves while someone else pushes clutch pedal.
Anthiron ·
the bowden tube still has bend is that what u mean by flat?
this sounds annoying.
Klaus ·
bend is good , other option is too pull inspection cover off in front of back seats and try and watch clutch tube while you depress clutch if it moves its busted free ,
throw out bearing might have crapped itself but this is usually heard via a squeel and grinding feeling in the pedal.
hellbugged ·
being firm and heavy before this incident i would blame the cable being installed with an issue from the first place..............is the hook on the clutch pedal itself ok?
and it seems to be engaging alright now despite the softer feel?
but as Klaus says if it went ping and the cable is ok, fair call that it's the clutch tube........check weld under inspection plate and braket right behine clutch padal hook........you can put another braket in the middle if the need arises, i can help out with location there if that turns out to be the problem
Anthiron ·
thanks for the tips guys ill suss it out tomorrow.
hook on pedal is in good condition.
how could the cable have been installed incorrectly? theres pretty much only one way to put them in?
grumble ·
If it is not the tube broken loose it may be a split pressure plate diaphragm giving the spongy low pedal.
Anthiron ·
wouldnt it slip if it was the pressure plate?
Anthiron ·
ok. so the tube is moving,
you can see it move through the inspection plate and more obviously through the inspection hole that the previous owner cut in the tunnel.
is this where it should be welded? (to the bulkhead it sits in at the front?)
are there only 2 mounts? because it looks like the rear is ok ( still bend in the bowden tube).
could any welder weld this up if thats the case and is the hole big enough for them to do the job without me butchering my tunnel?
Nicko
ancientbugger ·
Can't offer any help with the welding Nick but that is one hell of an inspection hole!!!
grumble ·
Yes if the pressure plate was split it would slip,obviously it wasn't this. A good welder with a mig will be able to weld carefully,watch the fuel tube.A hole saw makes very neat inspection holes that can then be fitted with a rubber grommet. cheers les
hellbugged ·
yeah Nick, the rear weld is under the inspection plate for the gear coupler..........that front inspection hole is like the grand canyon. i would weld that back up being a baja, cracks could develop from there for sure..........holesaws are your friend for this reason, never seen a crack develop from nice clean round hole yet, yes even left open🤖
we like to take the wing nut off the cable and slide the cable back and forth as the tube is welded, preventing it being welded but also intruding distortion/slag........
i slipped a tight fitting thick and large o.d washer over the front of the clutch tube (as per your pic, i actually cut the flared end off the tube to have the washer fit really snug).......that way the tube is welded in an area away from where it was done before (to this washer) and you can lay good weld around the outer of the washer to the flimsy bracket.........beats doing the two parts of the operation in one or two risky tacs
to take the pressure of the front and rear welds and stop the tube flexing, add a third braket while you are on the job........
......."middle" clutch tube braket added (this is in behind the passengers seat, 4 inch hole saw about 150mm behind the handbrake pivot pin........pick out the flexing clutch tube and weld a 2 inch piece of 1 inch angle steel under it, pry down the clutch tube to the steel angle and weld it to it CAREFULLY!).......
bushed ·
as for inspection holes it would be easier to cut 2 sides of a triangle with grinder and price out the piece to see.
lot less cuttin and weldin back.
Anyone think it may be a broken fork in bellhousing?
hellbugged ·
when the tube is getting loose and flexing, you have to wind up the wing nut beyond normal position, making clutch feel heavy..............then it goes ping and pedal will be all spongy and inconsistent and at the very end of travel will go harder as it finally pulls the pressure plate just enough to get a gear selected (feels a lot like broken cable)...........keep going with one broken mount on the tube, it will again go ping, and clutch wont do anything as the tube travels where it wishes to....
sounds like Nicks description to me.........easier to weld it all up, as this will last if done correclty, than it is to pull the motor and go looking for broken bits in there
broke the big steel ring that is between the two halves of the pressure plate that it effectively uses as it's pivot once...........pulled it all and couldn't see any probs so we cut and drilled the pressure plate open to work out what had happened, that's what we found. was a wierd break, wish i had pics
either way Nick, keep us informed as to what you find, always good to have an ending to these stories and can make a memorable thread to send someone too in the future..........maybe I can tell bushed he owes me a beer on it when we come accross each other one day (maybe i could owe him one too 😊)
Anthiron ·
ok ive found someone to weld it tomorrow morning hopefully.
ill keep you guys posted.
yeah that inspection hole is pretty messy, it was there when i bought the baja. i guess i probobly should neaten it up and round the edges and make a cover plate for it.
Anthiron ·
ok well i had it welded this morning.
ill take a pic today if i get a chance.
there are 2 individual beads of weld which look strong, im hoping it lasts. only cost 15 bucks.
i didnt do your washer trick joel, but if i breaks again ill go that way and put in a center mount.
it doesnt feel quite the same as before, i think the whole front bracket might flex a little.
credit daimo with that one not me 😂
funny what bushed says, was my first thought to
not broken but breaking fork
they sometimes make a nice mess when they go
i would just neaten up that canyon, not weld it up completely
always handy to have access there, really speeds up clutch cable replacements
hellbugged ·
Anthiron wrote:ok well i had it welded this morning.
does it feel lighter than before?
big washer helps stiffen that plate a bit too........not to worry.......next time 😂 ....glad youre on the road again
Anthiron ·
ha ha my bad. joel, daimo, you are both too helpful to tell apart sometimes i guess.
i dont know if its lighter, dont think it is. i know i had to wind down the wing nut quite a bit more than before.
i only quickly adjusted it to drive out of the panel shop, ill give it a good look over tomorrow and get some pics up.
thanks again guys
ancientbugger ·
Hey Nick, now you're up and running how about a trip up the beach in a few weeks.
Anthiron ·
sounds good barry, when were you thinking?
ancientbugger ·
I'm working the next couple of weekends then I'm off the following two weekends. I've still to get Mick onto the beach.
