As my heater channels are no longer connected to heat, i was thinking of running the cables for my audio install through them.
Just wondering if anyones done this before?
Ideally i would like to run something like hosepipe as a conduit from the front of the car (at the top of the A panels under the bonnet) and have it exiting through the rear heater port under the back seat near the battery.
Not sure how much room there is at the bottom of the A panel bit though...as it's obviously got to do a 90 degree there. Is there enough room?
If this is a definate no-go then does anyone have any other ideas for running cables from front to rear without doing the normal under the carpet job?
Neil
Hi Neil,
I ran some cables thru the centre section of the chassis.
the cable went in near where the fuel goes into the tunnel.. it comes out under a rear seat....
the cable was 7 core trailor cable..
djnee ·
