Wanted Subaru Flywheel bolts.
https://forums.aussieveedubbers.com/threads/78260/wanted-subaru-flywheel-bolts
MR930 ·
I need 8 subaru flywheel bolts suit ej22. The local Subaru dealer tells me he can't supply them and the bolt place can only sell me ones with a 17mm head which won't fit. Anyone able to sell me some ?
déjà vu,
i went through the same thing
let me guess you have an auto engine?
stock auto flex bolt plates were to short and aftermarket bolts had to bigger heads
all EJ manuals have the same bolts
if you have no luck let me know
i ended up having to pull a dead block out of an impreza at the local subi specialist to get mine but they may have some more
bushed ·
what mm are they?
8 bolts cant take that long to reduce the heads imo gently grind....?
put up some measurements
gogle some subi wreckers ie Wurtulla Qld and get emm posted
donn ·
Probably way off track for what you want but a mate of mine used socket head bolts when he couldn't get bolts with a small enough head, not the same application as you are after though.
thye have a pretty uncommon thread (M10x1.0) and the head is 14mm but they have a shoulder on them and have a fairly high torque value so u can grind the heads down and do them up with 8" shifter 😂
tassupervee ·
Nissan VG30 and VG30dett bolts are the same as the Scoob bolts. The dett bolts are about 5mm longer.
EXXIE new tho.
L8tr
E
