Putting vents into an early Engine lid ??? HELP!
https://forums.aussieveedubbers.com/threads/78375/putting-vents-into-an-early-engine-lid-help
I'm wanting to put vents into a 60's engine lid and also keep it looking "period". I think the factory convertable engine lid look is what i'm probably after......so where do i get the vents from ?
I think I read somewhere that you can use the vents from the front of a Kombi to be grafted into the lid ????
Pictures and suggestions is what I'm after !!
Craig T
craig find a crappy old 70-71 2 vent decklid and cut the vents out
thats what the 60s cabs had
or the 50s ones had vertical vents u could make from a bay window front grille
colonel mustard ·
the second one looks like a sad face.... You could also put a vent behind the number plate and space it out with something for more air flow.... 🙂
thanks Joel, its the 50's look that i'm after.............so bay kombi ?
the front grill on bays has vents like that but whether u can get them to bend like that
also might be a bit thin for welding
if u know someone with a stuffed bug shell u could cut out the vents below the back window and use them
modulus ·
Buy an Austin-Healey 100/4 BN2 and cut out the louvres from the bonnet....
hth
silver ·
buy this one
http://www.thesamba.com/vw/classifieds/detail.php?id=822061
at least it will be real
I dont think the curve - or lack of - is right with the bay kombi front grille bit
modulus ·
There was a engineering business in Albury (if I'm not mistaken) that punches in louvres; I have seen a Healey bonnet done by them and it was excellent - unfortunately the useful details like the business name have since eluded me. The point is, welding in a section is not the only option; you mght be able to get your existing lid punched.
hth
The BN2 louvres are different to the VW, they are cut and punched into a stock bonnet. You can get the cut and punch done using 'louvre cutters' They work well, and do a good job.
We have about 50 Austin Healeys, where I work at any given time. This is where I work
http://www.healeyfactory.com.au/
This way you can cut and punch louvres into the original metal without welding anything. Start ringing sheetmetal fabrication places.
modulus wrote:Buy an Austin-Healey 100/4 BN2 and cut out the louvres from the bonnet....
hth
I don't want louvres..........i prefer a "factory" look.
I wonder if the vents from a later lid mounted vertical would look any good.!
heres a fake cab lid made with 70-71 vents
nice and obvious with the bog burned off
OK Joel, you've convinced me !!................and I have about a dozen of the 70's lids
colonel mustard ·
Nice work Joel!! 🙂
I like the burned look there... looks cool, appart from the chrome bumpers!
yea just clear coat it, paint the rims red and narrow the beam.....🙄
hellbugged ·
christ Craig..........how big is that bat cave!
plenty to chop and bop here if the need arises, oval roof/vents cut if you want to go that road....i'll have a look around
just a little cave.........a bit like Dr Who's Tardis !!
lardo ·
Theres a place in the US, maybe motorworks cant remember for certain but they make repro early vents. do a google search might help.
donovan ·
check dirtbags work on sid in members rides. anything is possible if you have too much time on your hands.
Vents from a Golf bonnet work well, used to do a lot at VR using these and plenty available.
