Seat belt advice needed
https://forums.aussieveedubbers.com/threads/78414/seat-belt-advice-needed
DUB64 ·
Well with two kids I need seat belts.
64 Beetle
Any advice, ideas or thoughts?
I hate to ask but to get a drive I need to give in to the leader of the opposition who is demanding safety in the back seats.
Dirtbag ·
Hi DUB64. I've just started (sort of) on a 1970 bug and have had a bit of a look at the rear seat belt issue today. I think It'll either be a floor mounted retractor with a pivot at shoulder height in the rear pillar (reinforced of course) or frame up a complete parcel shelf and run the retractor unit in the parcel shelf itself like in a late 90's commodore. I think the floor mount would be the easiest as long as I can get enough strength into the C-pillar for the pivot to anchor to. Does that make sense?
matt ·
i put lap sashes in the backof my '60 beetle, I just drilled 2 holes through the floor and reinforced them with some 5mm plate and i also used the seat mount bolt holes to attach the lap sash
matt
DUB64 ·
Excuse my ignorance but do seatbelts need to beinstalled by a registered professional or something like that?
Dirtbag ·
They can be installed by anyone but they do need to be inspected to make sure they're safe.
Matt, did you use lap/sash, or just lap? If it's lap sash, where did you mount the top part of the belt that goes over your shoulder? Mine has no mounts up there, that's all.
pod ·
Dirtbag wrote:They can be installed by anyone but they do need to be inspected to make sure they're safe.
a 1970 beetle will have bolt holes up on the c-pillar,its up here
matt ·
i put just lap one in
matt
djnee ·
I got 2 kids....and use lapbelts with restraints. Cost $70 to fit.
Not sure where you are, but here's a list of fitters in VIC
http://www.onlinemechanical.net/child-restraints.html
grumble ·
Where are you Dub64,I would suggest a couple of child harnesses which mount above the rear seat just under the window,these are used in conjunction with a lap belt. Do yourself a favour and go to a restraint fitting station for the fitment. Cheers Les.
