Hi all,
We decided to spend our public holiday this week working on the baja since it's been largely neglected for the past month or so, when we fired it up it took a bit to get started which isn't unusual, however once it did start it died after about 20-30seconds... just shut down as though the ignition had been switched off. It started back up again easily, ran for another 20-30sec then died again... I discounted fuel as being the problem because when it stalled, it did so almost instantly, not a slow death so to speak. We checked all the obvious things like bad earths on the coil, ignition etc, we tried swapping in another coil just in case, but that didn't help. The distributor on it is a 009 i'm told, there's definately no points in there, so i can see it's not standard. There's also no seperate ignitor, so we couldn't check that. Someone at work mentioned that it might have a oil pressure cut off switch which may be causing us grief, but i wouldn't know where to look for it. It needs an oil change so maybe we can start there.
Has anyone got any suggestions we might be able to try?
Gerrard
bajaphreaks ·
