Does anyone have drawings/specs for a radiator header tank to be mounted to the firewall in an early beetle which would be suitable for an EJ22 conversion. I can get one made up in Aluminium once I have some details/starting point
ian.mezz ·
I think you can use one of those clear plastic ones that are in the water cooled Kombi
check hellbugged post .
I used a stock subaru one on mine.
i had an alu one made up for mine
nothing to it just 1.5L capacity, 2x 38mm spigots on the bottom and cap with overflow on the top
seagull ·
You can get a WRX or liberty twin turbo header tank its made of ally . dont get the black plastic one as they fail
rocknrob ·
i'm using one of those clear plastic falcon ones in the kombi but mightn't be room in a beetle🙅
55low ·
Joel,(Guy's)
I note that your inlet and outlets are vertical at the base of your tank, is this for ease of plumbing/mounting?
Does it matter if the inlet and outlet are on the bottom of the tank or should the inlet be form the side (horizontal) and the outlet be on the other side of the tank also horizontal?
Thanks Kel
Hi Kel,
it was just a neatness/ease of plumning thing with mine
it doesnt matter where the spigots are just as long as there well below the level of the coolant so that it traps air in the tank
