Hiya,anybody know how many times you can linebore a T1 case and the last size especially,i just measured mine at 66.5mm,oh and only tell me if its good news馃榾
Bizarre 路
I "thought" they were suppose to stamp what size they bore to on the inside??
I have heard of people boring to 60 thou (1 1/2mm :o ) but if it is for a hottie i wouldnt go past 10 thou.
No expert but i would be more worried about the thrust cut on the face. I think there is more hammering there from the back and forth rather than the flexing/harmonic of the crank
vw54 路
there are only 4 oversize back bearings available
Bizarre 路
true - 10,20,30 and 40 thou.
I have "heard" a few of the GEX's and the like use to 60 thou - dont know where they get bearings from
lugnuts 路
Thanks guys yeah the bearing had something written on it ile see if i can decipher it:thumb
lugnuts 路
Ok,this is on one of the bearings 2931 AIO72+1,50-STD on the outside and Fm L on the inside,this bearing is the big one on the end.This one is the little one on the other end of crank 2933 AT+1,50-STD BRAZIL.So sounds like this case is know a large doorstop,might get it ceramic coated as an experiment馃榾.
lugnuts 路
[Edited on 27-6-2003 by lugnuts]
Che Castro 路
if ur going for a hottie just get a good std/std used one, or a new case. its better in the long run i reckon
