for sale complete semi auto set up for beetle , everything works perfectly. included , starter motor, gearbox, torque converter , tanks, pedals etc etc $150 collection in caulfield mel. ph barry 0427024262
ctefeh ·
Barry,
Just to help your cause...what year is it out of? Also, does it come with the CV and transmission hoses? Converter bolts? Front (front of car) trans mount?
Anything left over from the motor?
Regards
Ctefeh
eraser ·
I wouldnt mind the flex plate if possible :P would need it mailed however, but if someone takes the whole lot thats fine.
mango ·
everything included except the oil pump from the motor, no engine parts available i just converted from stickshift to manual.
stickshift badge also available
What are You doing with the oil pump???
it cannot be used in a manual beetle...
the flexplate should be taken from the rear of the engine
it takes the place of a flywheel...
the torque converter and the special 4 bolts...
the crankshaft gland nut is different too.
mango ·
still available open to offers i want it gone
Airborne ·
Hi,
I'm after a flexplate and the bolt(s) to attach it to the crank- would you still have those?
