EFI haltech S3 crank sensor, M&W dual channel ignitor, coil pack, type 3 trigger pulley
https://forums.aussieveedubbers.com/threads/78678/efi-haltech-s3-crank-sensor-mw-dual-channel-ignitor-coil-pack-type-3-trigger
type3lover ·
Seller: Toby
Item: Haltech S3 hall effect sensor, type 3 pulley with Haltech rare earth magnets fitted, M&W dual channel ignitor and 4 post coil pack
Condition: good
Price : $200 cash or bank deposit
Contact: post here, PM or email briaros at optusnet.com.au
A great way to finally lose that dizzy once and for all!!
I bought this around 6 months ago and ran it on my type 3 successfully using a megasquirt II ecu. I have just changed to EDIS and no longer need these. Suitable only for an aftermarket EFI computer such as Haltech etc
The magnets on the Type 3 pulley are installed 180 degrees apart...one faces north and one faces south. The S3 actually sends 2 different signals to the ECU per rotation of the crankshaft...one every 180 for crankshaft position and one every 360 which provides a "home" signal and allows you to run a coil pack with wasted spark if your ECU allows it. The sensor alone is well over $150 to buy new!
Pickup or postage Australia wide
Useful info below on the Haltech s3 sensor and M&W ignitor...and the coil pack is from a hyundai and cracks out one mean spark!
http://www.tweakit.net/shop/product_info.php?products_id=185
http://www.haltech.com.au/downloads/connectors/s3_and_s4_hall_sensors_with_plug.pdf
http://www.thor-racing.co.uk/files/Double9A.pdf
type3lover ·
any questions?
Sides ·
You have PM, and I guess a bump 😉
type3lover ·
Cheers sides 🙂
I have added a couple of pics...the first one shows the sensor, ingitor and pulley...the other stuff in the pic is not included 😁
The setup is not unique to a type 3, although the haltech magnets (part # rem1) have been fitted by drilling and epoxying the magnets in to the type 3 fan pulley.
I suppose you could easily get 2 new magnets (roughly $6 I think) from Haltech and either modify the type 1 pulley or maybe look at the flywheel to trigger off?
👍 T
type3lover ·
Forgot to say, the ignitor and sensor both have plugs (not pictured) Ta.
type3lover ·
Looks like flywheel triggering is not an option...the magnets should be mounted in a non ferrous pulley...hence it was perfect for the type 3 application...click below for the installation guide from Haltech.
http://www.haltech.com.au/downloads/accessories/S3%20S4%20Hall%20Sensor%20setup.pdf
johny rotten ·
the type 3 fan is rubber mounted so your timing would have been a little shakey at best
Sides ·
Hey Toby... did you get my second PM ???
dangerous ·
The fan is rubber mounted, but isn't the pulley bolted directly to the centre hub?
type3lover ·
Hi Sides no I didn't get your 2nd PM please resend.
Guys, what is the relevance of this "rubber mounted" issue? The pulley bolt mounts directly to the crank.
Sides ·
Okie dokie - PM resent.
I've never looked closely at a Type 3 fan/pulley set up, so its got me stuffed if there's an issue there or not !!!
type3lover ·
Got it this time....and replied cheers dude.
type3lover ·
Sold pending payment
johny rotten ·
dangerous wrote:The fan is rubber mounted, but isn't the pulley bolted directly to the centre hub?
yeah my bad
you are right it would have been fine
