Stripped sump plug - HELP!
https://forums.aussieveedubbers.com/threads/78723/stripped-sump-plug-help
nbd1 ·
Just did my first oil change on '72 super & I think I've stripped the sump plug thread. It may have been partially stripped already (only did it up hand tight - left handed...), but it definitely feels bad & has slow oil drip from plug - can any Gurus ut there let me know what I've got myself in for.....
Thinker ·
Left handed
do you mean with your left hand OR left handed thread.
11CAB ·
Just replace the plate that the sump plug goes into. Get a strainer kit from a veedub shop as well when you get the plate
nbd1 ·
Hand was left, not the thread... Plug had some silicone type stuff around it when I took it off, so It may have been previousy over done... My excuse anyway...
Thanks for the advice...
Thinker ·
you need a copper washer or cloth washer and it dosent need to be tight to seal as it is not under presure.
A little thread seal paste may help to get you out of trouble.
In about 1973 VW deleted the sump plug from the middle of the plate, forcing mechanics to remove the plate and clean the strainer. If you can, get another plate or weld up the plug on the old one.
colonel mustard ·
http://www.classicveedub.com.au/SpareParts/Parts_Results_Quick.asp
where are u at we can suggest a place close
nbd1 ·
Western QLD - I'll phone around & get one sent out...
