Im looking for a 1500 gearbox in working condition, 1200 axles and tubes drum to drum without box, or even with box, either way, springplates, torsion bars and end caps.
Also an engine, 1500 or 1600 in working condition.
Thanks.
Sydney preferred.
Kuch
Kuchster ·
New info.
Kuchster ·
Anyone got anything?
pod ·
i have a 6volt gearbox ,bought it off e-bay .. $80 and its yours if you want it ,might have some spring plates and torsion bars as well,i`m at campbelltown
grumble ·
If you don't some close to home I will have a set of torsion bars,spring plates,caps etc and a couple of complete transmissions (6Volt) of unknown condition,or if you only need the axles,tubes,drums & backplates i also have a set of these. Let me know if you need them,I am in Taree.
Kuchster ·
I still need a 1500 gearbox, torsion bars and 2 end caps. And an engine. Hopefully not too far from syd.
Klaus ·
might have some short torsion bars , in the pile.
grumble ·
OK I have a 1500 transmission that jumps out of top gear with a pair of short axles and tubes.tThe torsion bars and arms, plates went to the crushers yesterday due to no response to the post.
Kuchster ·
Pod (Paul) gave me a set of springplates, torsion bars and end caps, thanks mate,
All i need now is a good 1500 gearbox and an engine. What sort of work is involved the fix the gear popping out?
bushed ·
Rob sometimes gear pops are bad coupling only,
loose coupling at square head connection on coupling only
or rotton bushing and not internal to box
