WTD: OE Exhaust tinware for EJ20T
https://forums.aussieveedubbers.com/threads/78831/wtd-oe-exhaust-tinware-for-ej20t
GTMac ·
Guys, anyone have the standard tinware from the headers? The tinware that you see either side of the sump. As my car sits relatively low I have worn thru the tin on speed humps and it rattles annoyingly.
Cheers, Andrew
Klaus ·
just remove it and wear thru the cast pipe like mine has ha ha.. bugger thru 2 sets out had the shits with keeping them.
GTMac ·
Klaus wrote:just remove it and wear thru the cast pipe like mine has ha ha.. bugger thru 2 sets out had the shits with keeping them.
Klaus, I dont believe you, you never throw anything out. How could 2 tiny bits of metal be giving you the shits? lol
pete wood ·
why don't you just plate it with some 3mm steel. if you wear through it just weld some more on.
GTMac ·
pete wood wrote:why don't you just plate it with some 3mm steel. if you wear through it just weld some more on.
Pete, just want it neat and stock as possible. Still looking please.
