1300 to 1600
https://forums.aussieveedubbers.com/threads/78850/1300-to-1600
edsta1963 ·
My 1600 beetle spun a bearing, crank and rod stuffed. I have bought a 1300 motor and after reading tech articles figure I can use my twin port heads, barrels and pistons on the 1300 block. I will also use the 1600 fan and barrell tin ware. Does any one know if I 1600 dog house oil cooler adapter will fit the single relief 1300 block? I hope it will be a simmple change over ???
there is an adaptor mount that you used to be able to purchase dont know if there still around
give Vintage a call 02-9789-1777
edsta1963 ·
Thanks no worries I will give them a ring.
edsta1963 ·
In my haste to strip the engine I forgot to mark the pistons. Is there way to tell which is the front? Also I was reading another tech article further on and it said to use copper gasket spray on the head surface to help seal the barrells as it aided in carbon build up, any ideas. Thanks
grumble ·
The piston has an arrow on the top that points to the flywheel.
edsta1963 ·
Thanks Grumble. Will head out to the shed tommorrow and start assembly.
