Item Description: Ported Street Eliminator Heads from CB performance. These heads come with 42mm x 37.5mm valves, double valve springs and have been bored by Stan Pobjoy for 94's. These heads were off a very low km motor (NOT MINE!) and Compression is set at around 10:1 for a 1916 motor combination.
Condition: Very little use.
Price: $990 for the pair plus delivery cost.
Please PM me if you wish to purchase. 馃槑
These heads have plenty of 'meat' and are ideal for a reliable high HP motor. The combustion chambers have not been modified, so there is huge potential to unshroud the valves to make even more power. I use these heads on both my ex hillclimb 1916 motor and my ragtop 1916 and have been more than happy with the results.
Craig Torrens 路
chambers
Craig Torrens 路
the little puppies together !!
barls 路
damn they look good craig but you missed the contact method in your post.
Craig Torrens 路
PM if you want to buy !
lohoon 路
pm sent
vw54 路
Craig
what CC are the head chambers
Craig Torrens 路
Hi Dave,
I'm not sure, but because the combustion chambers have not been touched you should be able to play around with the comp ratio for different motor combinations. I will try and measure tonight 馃憤
vw54 路
they dont look very big but need to know so i can work with them before purchase
Craig Torrens 路
hi dave, didnt get a chance last night so hopefully tonight for you.
vw54 路
yeah Craig that wood b TOPS
lohoon 路
check your pms craigo
vw54 路
come on Craig i need these for the Drags
johny rotten 路
barls wrote:damn they look good craig but you missed the contact method in your post.
Look out or I will tell dad 馃槀
Craig Torrens 路
SOLD
vw54 路
Oh Craig I was counting on those
Craig Torrens 路
sorry mate i had someone else deposit the dollars.
