Aussieveedubbers 路 Buying, Selling & Swapping Parts
F/S: NEW! early throwout bearing, 1600tp engine bits, type 3 bits
https://forums.aussieveedubbers.com/threads/78917/fs-new-early-throwout-bearing-1600tp-engine-bits-type-3-bits
bajachris88 路
New, still in box. should suit 61 to 70.
To my surprise, it didn't fit the throwout guide tube in my 1600 kombi box, and found out it was the wrong component. WILL TRADE FOR NEW LATE MODEL
$30 (save $10)
pm for details or if interested.
bajachris88 路
Off my semi auto. in great working condition, complete.
Before i stripped the car apart, i was locking up my rear end with the handbrake around corners in the turf. 馃檪 It proves something!
Slave cylinders don't look too old, no leaks. however, backing plate and drums are oxidised. Can wire wheel and paint up for another $50 in grey hammer coat.
These are surplus to my needs after upgrading to type 3 rear drums.
pm for details/more info/contact.
bajachris88 路
I'm after the tin for both the top and bottom of the heads. [Not the heater box tin though]
I'm willing to repaint them. as long as they are straight, no cracks or creases/dints/holes, i'm keen.
regards,
Chris.
bajachris88 路
No bearing noise, shaft play from what i'm aware of.
Working condition.
Also have other type 3 components, including fan shroud, fan, crank pulley and nut.
regards,
Chris
bajachris88 路
This is from a motor i bought quite a while ago, it was from a kombi.
I stripped it down, the bottom end was not bad, but was in need of a rebuild. Particularly after noticing there were wasp nests in the combustion chamber.
I was going to rebuild this, but have found another satisfactory long block with less work involved. the following are all vw standard.
1600 case. $40 ( no cracks. might need align bore, i don't know)
Cam: $20 (great condition)
Flywheel: $10
Conrods: $20 the set
Dual port heads: $20 a side. come with rockers and cover. Will need new valves, and a die grinder tidy up in the combustion chamber, not a nice smooth surface. No visible cracks though. I was going to reuse these, but now have another set.
Crankshaft: $10 (requires a keyway repair, and a repair to the dowelling for the flywheel. it was once an 8 dowel, someone filled in 4 terribly, and the 4 remaining are loose.
Barrels, $5 a piece. The pistons it case with were cheese, but these look alright. these haven't got any groove or wearline u can feel. oh course, need a rehone for another set of pistons.
Seller: Chris.
pm for contact or more info/questions etc.
trade accepted.
Pumba 路
Chris does it have the petrol pump???
bajachris88 路
sure i got it around somewhere. i will have a look.
I don't know what condition its in. it wasn't blocked off, and the motor appeared to be sitting in the weather.
bajachris88 路
Yes i do have it. its solid, one piece, no cracks / dints, and shaft inside still moves up and down.
Pumba 路
Got a picture??? im also chasing a good 009 dizzy.
bajachris88 路
will get a photo. (camera flat)
it did come with an oo9 dissy. it was full of those wasp nest mud things.
SO for full confidence...
A matter of new rotor, cap, bottom oil seal, and points, and it still works out cheaper than a brand new one, if ur interested. They aren't hard to rebuild, can do it in a matter of a morning. Reconditioned and good 'as' new.
Pumba 路
Chris PM me some photos of both the pump and dizzy,i have all the parts for the dizzy,let me know what $$$$ you want for them cheers shane.
bajachris88 路
bumpity.
sorry i ahven't got the photos yet shane, busy day mate. I will get around to it. my appologies.
Pumba 路
No worrys cheers shane.
