This was possibly the most unpleasant job ive ever experienced. I used the guide that one of the members (Joel) has posted, http://forums.aussieveedubbers.com/viewtopic.php?tid=68078
and it was extremely helpful, HOWEVER everything that could have gone wrong went wrong.
This. Is. My. Story.
Started off as a normal day, and I decided to replace teh bushing on my 74' L bug. I was going fine until it came to the part where i removed the coupler and attached some string to the end of the rod.
As i was pulling it through, however- i somehow managed to drop the string in the abyss of the gear shaft. I couldnt get to it and after much french I just decided to pull through the rod, but after i got to the end of it, i retreived the string and decided to attach the end of it to a peice of wire and rethread it.
BUT, once i had re threaded it, I began pulling the rod through and i found that it had threaded just below the stupid ring which usually housed the bush. SO then i had to thread the rod BACK to the front and repeat the process cept this time I would make sure it would tthread through the ring.
As i was doing this, the wire attached to the string suddenly got caught on something in the shaft. So i spent the next half and hour trying to remove the wire- only to force it so much that it snapped in my hands (AHHH). SO i then had to cut the wire in a spot that wouldnt get in the way of the gear rod.
From here on, I just began to thread through the rod without the aid of the string. But, since i had tied a knot with the sting to the rod it wouldnt fit through the tight bush hole. SO I had to first cut off the string, thus defeating the whole purpose of the bloody thing.
The last obstacle was rethreading the rod when it got stuck a further 3 times and i had to pull it back and rotate it and stuff. And finally- FINALLY i had reattached it to the coupler.
And thats my story. I could have told the numerous other minor details which made this thing a PITA
Moral of the story is. DONT USE STRING! (or drop it if you do).
This was supposed to be a 2hour job but it ended up being 5+ hours for me.... It was a character building learning curve haha.
THE END.
*sighs*
Burgo ·
