Leaking pushrod tubes on a 36hp
https://forums.aussieveedubbers.com/threads/79074/leaking-pushrod-tubes-on-a-36hp
matara ·
Is there a way to stop a leaking pushrod tube on a 36hp engine without pulling the engine out and taking the heads off?
nope has to be replaced with new one and seals engine out heads OFF
bajachris88 ·
IF you got the tools (torque wrench and sockets)
You could have it organised in a whole morning easily. The seals cost next to nothing either.
dont forget the seals and tubes are completely different to later engines not same size
matara wrote:Is there a way to stop a leaking pushrod tube on a 36hp engine without pulling the engine out and taking the heads off?
You can take the old pushrod tubes off...
and replace them with the adjustable type
using new silicone pushrod tubes.
I always cover both sides of the seals with Permatex non hardening gasket cement, I hope this helps..
Ring Mick Motors etc and ask if they are any tricks to doing the job..
no you carnt as there a different size not available in the split adjustable tubes
dangerous ·
Yes much smaller seal.
Youn could always make some.
There are various aluminium tubes that slide within each other.
You can machine a step on each end for the seals,
and flare the larger tube to accept another seal in the middle.
a circlip and a spring to keep the tension on the seals.
Just like the pauter ones in this link:
http://forums.aussieveedubbers.com/viewtopic.php?tid=47383&page=2
grumble ·
You will need to remove the cylinder heads as the seals go as hard as a rock over time.If you need the seals or a gasket set I have both.Cheers Les
