I fitted a VDO oil temp gauge with the compatable VDO sender last weekend. I tapped the sender in the T3 block off spot in the case. To my surprise the gauge was reading 125*C after about 25mins driving. At this stage I am getting pretty worried about that reading as it seems a little to high. I then got a digital probe thermometer and checked the temp down the dipstick. The dipstick temp reads 90*C when the gauge reads 125*C
Seems like the gauge is way off. I knew VDO gauges are not renown for accuracy but 35*C???
I tested the dipstick thermometer in boiling water and it was spot on 100*C.
My question is can you put a resistor in the sender circuit to give accurate readings ? or just live with the 35*C difference.
alien8 ·
