Welding a horn ring
https://forums.aussieveedubbers.com/threads/79115/welding-a-horn-ring
karmannghia60 ·
I think it is cast iron so not sure how to repair it. See pic below, its broken in two places. I was told that brazing rods could be used to repair it. I never used brazing rods before, can I use them with a butane gas torch or is it not hot enough?
Raf
HappyDaze ·
If it is cast iron you could bronze weld it using tobin bronze rod, with cast-iron flux, although you will need an oxy-acetylene torch. Vee out each join first with a file - not grinder - and weld one side at a time. Don't rush it. Good luck!
Cheers, Greg
