Mildoval56 ·
I need to remove the doors from my 56 Beetle. I can't loosen a single screw - is this a common problem? Any suggestions? Would it be quicker to drill them out and replace?
https://forums.aussieveedubbers.com/threads/79153/door-removal
Mildoval56 ·
bajachris88 ·
grumble ·
Mildoval56 ·
cb john ·
eraser ·
1500S ·
That "thingy" is called an IMPACT DRIVER Chris!! Everyone should have one in their toolbox.bajachris88 wrote:don't bother using a philips head screw driver. they are tight as nuns!
If you can get a philips head bit on the end of a socket, and use a wrench, that would be the go.
OR
From supercheap for $13 ish, you can get a hammer wrench/punch/driver thing, takes philips head socket bits in the end, wack it with a hammer and it rotates it (to loosten tight philips head screws)
If using the socket, obviously push hard so not to stuff the head of the bolts,if you have those little hexagonal screw driver bits (for drills or bit multi screw driver things), and can find a small enough socket to take it, than that will be the go.
(BTW. the bit that holds the super cheap hammer punch thingo, has a 1/2'' socket bit (detatchable) on the front of it and will hold the philips head bit it comes with. Put it on a 1/2'' wrench and bobs ur uncle!
