Aussieveedubbers 路 Tech Talk
IRS suspension setup
https://forums.aussieveedubbers.com/threads/79186/irs-suspension-setup
chris1 路
Hi,
I have an IRS setup from a VW (well, the arms themselves are custom, but the rest is all VW) on my buggy.... each side has the arm joined onto the torsion bar, and the "inner" side of the arm is bolted through a bush (using the big IRS bolt, and 2 big washers)...
now, when I dismantled it, it had one washer on each side of the bushing, however, I was told that both washers are supposed to be on one side of the bush, but I can't remember which side he said :P
can anyone enlighten me?? 馃檪
hopefully someone understands what I'm talking about.... 馃檪
Midlife crisis 路
There is no wrong or wrong where the washers go it depends on how your arms line up for rear wheel alignment, you move the washers from side to side on the bolt to adjust the trailing arm.
Someone else may have a better description on what they do but that is the basic idea.
Marc
Craig Torrens 路
both washers on the outer side. 馃憤
chris1 路
thanks 馃檪
just to confirm, that is, both washers should be at the "head" end of the bolt, not near the thread?
dangerous 路
yes
