FROSTY wrote:I have been running a Mallory twin points dist for years ( old school) without a problem. I picked up the Voltmaster 2 coil that is matched for this dist and it destroyed the points in about 5 mins. what would cause this? Wires neg- to the dist, pos+ to the ignition switch.
any suggestions.
the Voltmaster coil is probably very low resistance with very high Output Voltage...
You are making the points work too hard...
maybe two new condensors would fix the problem??
How old were the points??
I just had to renew My points as the rubbing block had worn down and was shorting out on the shaft...
Just go back to the other coil you were using..
but still sounds like Your condensor has had it...
If the coil needs a resistor - its usually printed on the coil..
