I was at the wreckers this afternoon and spotted a written off liberty.
I popped the hood to find the complete engine, not even the battery had been taken.
I need to check out what size it is and what and where everything i would need for a conversion is in the car.
Speedy responses would be appreciated because i think bits will be missing very sooon.
all libs were 2.2 till about 96 then from 96 to 99 they were either 2.2 or the pov model had 2.0L
its stamped on the engine block just beneath the alternator
did you notice what year it is?
71-BEETLE-SEDAN ·
I tried but preety much all the writting was in chinese or sumthin.
But ill probably go check it out again tomoro so ill let you know.
The only other thing is is there anything important in the corner where the battery is, it was the only spot that had real damage.
just check the the timing belt area hasnt been damaged
ej22 are non-interference motors but if the cam gears been hit the belt may have jumped a tooth or 2
but nothing terribly important
just the fuse box which isnt needed
71-BEETLE-SEDAN ·
Okay
Ill write a list of stuff that you have listed on your other thread and let you know how it all goes.
seagull ·
71-BEETLE-SEDAN wrote:I tried but preety much all the writting was in chinese or sumthin.
are you sure its not an import ? IE JDM Grey import
Take a photo and post it up
i'd be surprised if it was
i know on mine pretty much only the australian compliance plate was in english
the one with paint, trim etc had a lot japanese scribble on it
71-BEETLE-SEDAN ·
There was one plate that was english but it was all scratched up and was on the drivers side and the jap one was on the passenger but ill get pics up today at some point
BlueV2 ·
I could be wrong, but there should be a year stamped inside the oil filler cap. Nothing to say it hasn't been changed with another engine, but it might be correct.
71-BEETLE-SEDAN ·
Here is the engine,
Here is a pic of the VIN plate.
I need info on engine size, because i saw a website that said its a EJ25 but i saw EJ22 stamped on the block.
Also the guy wants 650 for it, how should i check see if it runs.
is $650 the whole car or just the engine?
its a 22 by the way
if theres no damage to the timing belt covers and nothing touching the fan belts putting the donkey dick back on the throttle body and airflow meter it should run if nothings damaged in the fuse box
The way I would see it.
The motor would have to have been running for the car to be driving to be smashed!
If it has done under 200,000km, then maybe it will be good for another 100K, depends on it's service history
If it has only done low 100K then it should be a good one.
You would be very wise to fit new cam belt kit and new water pump no matter what when you put it in your car. They are good insurance.
You need the engine complete with flywheel air flow meter, wiring loom with relays igniter computer, engine mounts, exhaust just past catalytic converter including O2 sensor and wiring, carbon canister.
No harm in grabbing all hoses at the other end, not at the engine end, if you get to take it out yourself. Grab the fuel line clamps on the high pressure fuel lines etc.
I got all the above removed from vehicle and delivered from a 112K km vehicle for $1100 a few years ago, so $650 is real good.
71-BEETLE-SEDAN ·
650 for the whole car.
Couldnt check kms cause didint have key but fuse box is ay okay. Timing belt covers i dont know about, i could turn the thing at end of arrow.
What do i do bout the key. If i could get the ignition switch out of the barrel and use a screwdriver is there anything stopping me starting it.
Ive got one exam in the morning then i should be able spend an hour trying to get it to kick. I plan on taking oil, coolant, water and bit of petrol.
Is there anything else i need to take.
The whole car i spreety smashed, here is a pic.
thats only the A/C compressor clutch so it will spin on its own
you wont need the key to check KMs they didnt go digital odometers till late 90s
how the passenger side for damage? cos to fold in the middle like that has takes a fair impact, it may spent some time on its side
$650 is ok from a wreckers for teh whole car if it runs ok
it takes a good day to pull the looms out of them so its worth getting the whole car if poss rather than them cutting the shit out of the loom
71-BEETLE-SEDAN ·
left side seems okay cause mirror etc is still all intact.
I would be bringing the car to mine so ill be removing it all.
where bouts is the odometer cause had a look but couldnt really see.
But will i be able to start with just the ignition switch
seagull ·
I have cam covers here if you need them + other bits & bobs
Is the car maual ? duel range ?
looks clean from Perth
seagull ·
3 hours to get the motor & loom out , just cut the front off with a 9" & lower it out the bottom
its just in the middle of the speedo
it would have the same dash as mine they never changed it in that series
71-BEETLE-SEDAN ·
Yeah i had a look couldnt see it but, will check on way to school tomoro.
And its an auto.
Do you think i could see the doors and interior bit to get some money or what
you can try but its not really worth the hassle cos you get bugger all for them and lots of people wasting your time
pretty much all mine went to the crushers, the headlights and back bumper sold gearbox is still there
if its AWD then the gearbox will sell easy but FWD cant even give them away
71-BEETLE-SEDAN ·
Okay cool ill check that tomoro.
Will have a look for logbooks and stuff too.
What does noise am i looking out for if i get it started, like lifter rattle etc
seagull ·
The last FWD auto I had sold for $280.00 as it was needed for the out put shafts ( stubs out the auto )
Front drive shafts $130.00 ( larger than wrx units )
Electric door switches $200.00
Tail gate $180.00
carpet fits sedan or wagon $100.00 ( mine was clean )
$100.00 scrap for the shell
$78.68 loose change in the car
71-BEETLE-SEDAN ·
The tailgatei think is stuffed but yeah will check
Would that be much different in NSW
seagull wrote:$78.68 loose change in the car
No way. Are you serious serious or messing with us serious?
71-BEETLE-SEDAN ·
Didnt get to the wreckers today but will tomoro.
I plan on making a list of all sellable items on the car and then checkin on the net.
seagull ·
yep , that what the kids found
The RS turbo I have I found over $70.00 , three early $10.00 notes & the rest small change. To my shock needles & some packets with white powder & these little stamps with faces in yellow like this 🙂 . No idea what they were & went in the bin
from now on the kids dont get to look first !
I named the RS , the drug runner
Baja Wes ·
that's a classic Neil.
I bought a 73 superbug for $50 to get the IRS gearbox, arms, cv's, etc to do my IRS conversion on my Baja. It came with free rats living under the back seat, and an awesome quality pair of blue plyers which I still use regularly! Not as much fun as $78 and some drugs 🙂
71-BEETLE-SEDAN ·
Update,
Its done 17100 kms, battery was dead today but got jumperleads for tomoro.
Tailgate is salvage able, its got non electric winows and the dash is stuffed cause of glass rubbing on it.
How much do Subi brakes sell for?
And how do i tell if its AWD
seagull ·
your looking for a tail shaft that comes out of rear of the trans and goes to the rear diff
stock brakes dont sell
seagull ·
If this has been on it roof , you would be best to remove the spark plugs and crank it over with out them. Water / oil / fuel is not able to be compressed and if there is any chance of these in the cyl when you start it there is a chance it will throw a conrod.
I think this is a FWD auto , as there is no fuse on the driver side strut for FWD mode over ride.
71-BEETLE-SEDAN ·
I dont think its been on its lid because there is like no paint missing of the roof, just the places near the creases and stuff.
I will check about the AWD.
if its got wind up windows its an LX so wont be AWD
its got the tranny duty resistor same as mine on the RHS strut tower so ya FWD auto
mine was a GX with power everything and the doors still couldnt be given away i think the scrappys made more money from it than we did
seagull ·
Mines LX and its AWD 🙂
71-BEETLE-SEDAN ·
Okay. Few questions now.
What gauges am i gunna need.
What diameter pipe should i try and use for cooling.
Has anyone made scrape shields or do they make it harder for the heat to dissapate.
Can i use the stock fuel pump.
seagull ·
Mate , you are best to go to Joels wright up , he covers a lot of this in his post with photos. a lot of on going effort there
I under stand your young , just try to be mindfull what your doing & possably leave the 9" grinder to some one that knows what there doing. I would hate to read you have cut your arm off.
seagull
seagull wrote:Mines LX and its AWD 🙂
well there ya go, you learn something every day
i knew GX came in both, ive just never seen an AWD LX and all the subaru listings ive seen only have FWD LXs
seagull ·
Mine was FWD & I converted it to AWD , but one can never tell unless you look under the body. There is so many FWD to AWD conversions out there these days one needs check
seagull
71-BEETLE-SEDAN ·
Okay, ive decided that im not going to start the conversion until november of 2011. This will give me six months to complete the conversion so that it will be ready for me when i get my blacks.
Ive decided to go with the 2.0 turbo, not sure about trans upgrades but because its far away i may get a new one done before. I plan to keep my bug on the road till 2011 so i was wondering what parts can i start to collect to make it easier to do when the time comes. The long plan will help with costs because i plan on getting a job soon so will by bit by bit and be able to upgrade it as i go.
I was at the Highlands motor fest and spoke to a guy with 3 libs sitting at home and all run just no rego so will be speaking to him alot. i plan on buying a whole car in best shape posssible so that can scavenge for parts.
I have got a list together of all the parts i think i will need and rough prices.
Idlike to thank everyone that has helped so far and who will continue to help on this forum.
ericos_bob ·
Don't mean to hijack the thread but speaking of selling off liberty parts I also have a subaru liberty conversion going in a kombi and no idea what I could salvage and sell from the donor.
T's s a 1992 gx automatic AWD which has done only 80,000kms. All electrics work and all interior is in brand new condition. What bits would be worth selling off before bringing to a wrecker. How much would you be listing the auto trans and AWD components for? Air conditioner was just re gassed do you think it's worth selling? cheers,erik
seagull ·
do some home work on RS liberty forum, and were are you located
ericos_bob ·
Ok will see what I find there. Am in adelaide
71-BEETLE-SEDAN ·
Seagull, what gearbox are you running with your turbo block?
