Hi,
I am looking to sell my king & link pin beam which has had all the yummy mods done. This beam slowly got built up as I ran my perpetually in project stage bug, so probably the most KMs on a component (apart from the original beam itself) is at the most 5000 (and I think that is a major overestimate). Selling as I went to ball joint as the brakes I wanted were easier to adapt to ball joint.
Here's a rundown on what's been done:
- CB Performance disk brake dropped spindles (2.5 inch drop). Very good option if you want to go Porsche drilled rotors on a link pin bug with decent stoppers. 2000KM use. Painted with POR15.
- Koni adjustable dampers. 2000KM use.
- Whiteline adjustable swaybar. I ran this on just a stock front end and it adds a lot to the fun factor 馃檪. 5000Km use.
- Rebuilt K&L pins. 2000KM use.
- Welded in adjusters. Mid-way placement to raise (since you've already got 2.5 inch drop in the spindles) or even lower some more (!).
- Recently stripped and painted with black enamel. Not a super resilient finish, but better than a patchy 40+ job.
In short this is a freshly rebuilt, ready to run beam that is an awesome street level of tune.
Here are some pics. Note I have just dummied up the assembly (I had stripped it down to paint - was doing my ball joint beam so why not this) and have only really finished one side, but all beam components will be assembled and included with the exception of a steering box and dogbone.
I am looking for $600. When you consider the spindles cost $200+, sway bar $200+, shocks $300+, + adjusters, +rebuild, that is a massive loss for me and a massive bargain for you.
Located near Moorooka, Brisbane. Preferred contact is post/PM.
Thanks for looking.
Peter
pudgy 路
