Wanted - Hot air pickup pipe
https://forums.aussieveedubbers.com/threads/79303/wanted-hot-air-pickup-pipe
Matt Ryan ·
as stated above, to suit twin port Beetle engine.
It looks like this:
Regards,
Matt.
hard to tell - but is this one??
Came out of a stash that "could" be air cooled 2L T3 type 4 stuff??
Think th e end is different??
Pumba ·
I have one here that came of my 1500 single port beetle,it looks the same as yours Bizzare ???
colonel mustard ·
I had one but threw it out..... what model are you after?? might help others 🙂
alien8 ·
i got one sent over from aircooled.net. its called a preheat elbow. $15 or so
Special Air Service ·
Matt,
I will have a look in my stuff before next weekend, I think there is one there.
Brendan
Matt Ryan ·
colonel mustard wrote:I had one but threw it out..... what model are you after?? might help others😊
colonel mustard,
As stated in original post, it's for a twinport Beetle engine, 1300 or 1600 will be the same. Mine's a 1300 tp but it's in a '61 model so, year model is pretty irrelevant.
Special Air Service wrote:Matt,
Brendan
Thanks Brendan,
I'll see you at Old Bar, pm me your mobile no. so I can find you when I get there.
Regards,
Matt.
Matt
there are a few different types of the hot air pipe
depending on what engine tin ware you have fitted
Matt Ryan ·
Dave,
Will be fitted with stock 1300/1600 twinport rear tin, with single heat risers.
Single or twin heat risers was the only difference in late (twinport) rear tin as far as I know.
Regards,
Matt.
vwperformance ·
Hi I have one $15 plus postage,let me know if you are interested.
Peter 02 43257911
Matt,
dont have one sorry
Brendan
Matt Ryan ·
Bizarre is sending me one, I'll see if it fits.
Thanks Barry.
Regards,
Matt.
all the 12volt bug ones are the same overall just minor cosmetic differences
from memory upright kombi engines had the same animal too
alien8 wrote:i got one sent over from aircooled.net. its called a preheat elbow. $15 or so
You can usually pick them up for $5 at swap meets....
Most beetles no longer have them..
but still have the 50mm hole letting hot air into the engine compartment which is a no no...
