Horn Problem
https://forums.aussieveedubbers.com/threads/7942/horn-problem
squarebacker ·
I have a T3.
The horn goes off when I turn the steering wheel to the 11 o'clock position.
Wots up?
The steering coloum or tube needs insulating.
pyr0 ·
sounds like ur car needs medication, sounds like its got terets syndrom
Pretty sure early bugs have a wire that runs the lenght of the steering tube that is eathed when the horn button is pressed.
That wire will be worn and earthing when at 11 o'clock
Pretty sure it is a bugger to replace. Might be easier to put a horn button on the dash? 🙁
sikdub ·
Check the wire that is on the steering coupling underneath the fuel tank, if this is broken it could earth out and make the horn go off when it contacts the body.
Steven
