Airconditioning
https://forums.aussieveedubbers.com/threads/79446/airconditioning
ryana89 路
I'd just like to ask, has anyone had experience with airconditioning in older VW's (beetles, combi's) and if its effective or even practical. I know its possible from reading a bit from Joel's "Subabeetle" thread, and im just a bit wondersome about the whole idea. I tried looking for a thread about this but couldnt find one (feel free to link me if one does exist)
Thanks in advance
Ryan馃槀
helbus 路
My experience is that it is not necessary.
Joel 路
it was easy with mine cos the subi engine already has the compresssor on it but its not hard with a vw engine, im noticing more and more at shows with it fitted
theres a bug getting around here with factory A/C but its pretty hopeless system ,the old 70s york compressors were a one size fits all deal, the same thing in little vws that was used in huge fairlanes and statesmans and they really used to load up little vw engines
main problem in a bug is finding somewhere for the condensor that has enough room to fit the right size and good air flow
modern rotary R143a compressors are alot more effeient so dont load the engine up
its not a cheap option, im looking at around $500 just for all the hoses, starting from scratch you still need a compressor, evap, condensor etc
might be cheaper to import one of the kits from the states like gilmores
http://www.gilmore-enterprises.net/main.html
ryana89 路
Thanks Joel and hellbus, i thought those were some of the difficulties with installing a system. I've seen the power a compresser can suck even from a modern EFI engine (Mazda 626), not sure how serious it would be a with a small 1600 engine, but im getting ahead of myself anyway. Thanks for the imput馃榾
Baja Wes 路
I have it, it's awesome, do it 馃檪
Although I have the V6 to move the compressor.
11CAB 路
Gold Coast VeeDub at Labrador do A/C installs on old veedubs
Pauld 路
id like more info on this, the last two weeks in darwin have been 35 degrees and humid as anything so if theres a kit floating around in aus please let me know
LUFTMEISTER 路
Have you tried those little flap windows? = Captian Obvious 馃槈
Camo 路
Note - David Birchall must be in transit from Warwick at this point and cant add a comment, so I will chime in for him 馃槀
I have seen Boris at Vintage Vee Dub doing an install on an old Beetle. Try them.
Depends where you are Ryan ?? You now have a couple of options.
Kev
Baja Wes 路
When it's close to 37 degrees or hotter those little flap windows just make you hotter as the air is hotter than your body. They also don't do anything in traffic.
71dub 路
worth a call to gold coast vw they have installed quite a few.should be able to answer all your questions
ryana89 路
Thanks again for all input馃榾
I live in Hervey Bay, which is basically the middle of nowhere for buying/getting ANY cars, or accessories
Thanks馃槀
68AutoBug 路
Pauld wrote:id like more info on this, the last two weeks in darwin have been 35 degrees and humid as anything so if theres a kit floating around in aus please let me know
You would need air con in Darwin as the Humidity up there is terrible,,, IMHO
same as Singapore & Malaysia
where most beetles have air conditioning....
it was an option on beetles in the USA...
I have seen it on imported Karmann Ghias from the US..
is costly unless you use generic parts...
PS" there is a Beetle owner on here who has had Air Con in His beetle for about 20 years.. lives in Queensland..
Baja Wes 路
68AutoBug wrote:PS" there is a Beetle owner on here who has had Air Con in His beetle for about 20 years.. lives in Queensland..
That's Grahame, he's a really nice guy. He posted in this air con thread - http://forums.aussieveedubbers.com/viewtopic.php?tid=5405&page=1#pid40689 - his forum name is old dubber.
azrael_kadeus 路
i've been trying to search for air con in beetles... there isnt much info or pics up on here..
jjwebb123 路
it would be nice,but i really couldn't be bothered with it.its just another thing to worry about.
but if done the right way they can be excellent.馃槒
mackaymanx 路
Joel wrote:,the old 70s york compressors were a one size fits all deal, the same thing in little vws that was used in huge fairlanes and statesmans and they really used to load up little vw engines
The "old" (these are still available new) York compressors come in three different sizes, 100, 142 and 169 cc/rev. The pulley ratios also affect the flow the compressor makes, the engine loading up has more to do with the poor horsepower that the vw motor makes. Also the vw's used the super-compact model which were shorter.
Yes, a modern ac compressor will be more efficient.
Uber Kafer 路
fair bit of stuff available in the US, particularlly the full installation kits, unfortunately the under-dash evaporator module is designed for left hand drive cars. One major item is the compressor mounting brackets and they are available as a kit from businesses such as ISP West etc. So that saves major time and hassle designing and building your own brackets. Mexican beetles had it as a factory option, so theres a lead. The lower nose panel on later US models had the wide grill, I assume that was for the condensor air flow but I have never seen a picture of what mounts behind the grill.
As for the under dash evaporator unit is there an item that people have used successfully in Australia?
Joel 路
the parasitic power loss with the york and tecumsei piston compressors was incredible
Piston compressors in cars are way less effecient than rotary compressors.
they were actually used and still occasionally are on medium temp cool rooms 馃お
they woulda got the temp down quick if vw didnt undersize the condensor and evaps so badly
theres a jap bug around here with original A/C and one of the orginal tecumsei compressors
which still worked till a few years back when the old girl hit a guard rail and damaged the condensor
power loss was described as "noticable" 馃槀
ryana89 路
Some of you may be interested but I found a simple bodgy version a while back of how to cool your car cheaply.
http://www.instructables.com/id/Portable-12V-Air-Conditioner---Cheap-and-easy!/
It would be nice to see a thread about the actual install of an A/C system but I havnt seen one.
Perhaps there's somthing on The Samba?..... Ill go check馃榿
Over and out
modulus 路
ryana89 wrote:... I've seen the power a compresser can suck even from a modern EFI engine (Mazda 626), not sure how serious it would be a with a small 1600 engine...
My wife runs a Holden Astra with an 1800 efi engine. When you turn on the a/c, there is no noticable drop in power. Methinks the newer compressors are much more efficient than the older models.
hth
mackaymanx 路
At 125 bhp (93 kW; 127 PS) the 1.8L Astra has over twice the power as the humble VW 1600. Yes a more efficient compressor helps, so does twice the horsepower.
grumble 路
Try a Datsun 120 auto with air!馃檯
Joel 路
even that would whoop the ass of a 3cyl 543cc suzuki mightboy/alto with A/C and a 2 speed auto 馃槀
one wonders why something so rediculous was ever created
Ampdub 路
I have heard of people using compressors from 12volt fridge/freezer. a Danfos or something like that. pop into springers and ask them.
