Lowered rear shocks?
https://forums.aussieveedubbers.com/threads/79494/lowered-rear-shocks
alien8 ·
So I know that when you lower the front you usually run with a lowered shock or strut insert but what about the rear?
Do the part places carry a shock for a lowered rear or is it the norm to just use the stock shocks?
If any one runs lowered rear shocks where did you get them , what brand and part no.?
Many thanks Brad.
you can use normal ones (within OE suspension stroke limits) because the bump stop is separate
alien8 ·
I was just thinking about ride quality with rear gas shocks. You would think the ride would be softer with a shorter gas shock ?
no, disrgarding bump stops, the ride height doesn't affect ride quality. Shock/spring rate does
Klaus ·
I run empi 9650 shocks from classic in my split front and rear , cheap as chips and do the job until i can sort some adj koni's.
