Framehead Information required
https://forums.aussieveedubbers.com/threads/79541/framehead-information-required
RAT061 ·
Hi guys, i am in the process of planning to build a Volksrod. If any one has the spec's for a Linkpin Framehead eg the distance between the mounting holes, beam diameter etc as i currently don't have my car at home.
Regards,
Tony
Dirtbag ·
Hi Tony. Sorry I haven't got back to you sooner. I have an early beetle arriving here at the end of the week (hopefully) so will be able to get some measurements to you.
Tim.
dangerous ·
tubes are 52mm diameter.
cant tell you the spacing for link pin, but 120mm rings a bell for c-c distance.
RAT061 ·
Guy's, thanks for the help
Regards,
Tony
RAT061 ·
Hi all, still trying to locate some spec's for a Linkpin Framehead to assist me in building my volksrod.
Dirtbag ·
Hi Tony, sorry I've been so slack. Dave is right with the 52mm diameter tubes, and mine measures up at 118mm from the centre of top to centre of bottom beam. The 4 mounting holes I measured from the centre of each hole. 290mm apart horizontally and 52mm apart vertically.
I hope that helps. Let me know if you need any measurements as I now have a couple of link beams here as stock so I can measure them easily.
RAT061 ·
Thanks mate, i have passed the info on.
Tony
