Hi guys, I'm selling a rotary engine adapter conversion kit (that Rose has been advertising for me) that I believe is to suit a kombi gearbox but have been asked what model?(1600,1800 or 2000). Is there any difference and how can you tell? Also is there a difference with the flywheels as this comes with a custom flywheel that has the rotary centre and cast eccentric shaft balancer grafted to a VW unit outer and then all matchined and balanced. It has been used going of the wear on the puck friction plate so I know it works and but am unsure of the fittment. any help appreciated. See attached photos. cheers
Any inquires call me on 0411 470 690
bajachris88 ·
how much for it again?
I will go measure the stud pattern for my 1600 kombi box round the corner...
gimme a sec...
blow in ·
$200
bajachris88 ·
obviously 4 stud.
centre of bolt to centre of bolt approx 196mm (+- 2mm)... NOT DIAGONAL, BUT BOLT ABOVE, BOLT ACROSS. (for 1600 3 rib kombi box)
But that clutch pressure plate look like an early style... someone correct me if wrong...
but talking pre-1600 engine....
bajachris88 ·
is it a 200mm flywheel? or 180mm? diameter
what year kombi did u have it on? if we showed pics of the box could you id?
If it was for a 1600, i'm keen on it. 👍
blow in ·
I never used it. Guy gave it to me in lue of money owed and took since I thought a manx/12A turbo project would be fun.
They are all the same, kombi beetle and type three..... the ONLY difference is 2.0liter kombi has a deeper bell housing and longer starter to match, but mounting and ring gear diameter are all the same.
blow in ·
I've got measurments between bolt hole centres starting from one bolt going around in a clockwise pattern of 210, 215, 200, 215mm. The flywheel has an outside diameter of approx. 275mm. Might be some more discussion on this I think.
blow in wrote:I've got measurments between bolt hole centres starting from one bolt going around in a clockwise pattern of 210, 215, 200, 215mm. The flywheel has an outside diameter of approx. 175mm. Might be some more discussion on this I think.
Flywheel would be more like 275, it's the clutch diameter that is 180 (unlikely), 200 (most likely), or 210, 215 or 228mm.
bajachris88 ·
rekon it might be for a splitty matt?
I'd say for any vw trans. That pressure plate looks like a 200mm 9 spring, they use 9 coil springs instead of the more modern diaphram.
