Gday,
I was just wondering how much modification is needed to fit 1800 heads to a 1600?
And can I use the 1800 pistons and barrels for my 1600?
Cheers Joel.
Joels72Lowlight ·
Also what is needed to fit a type IV into my 73 Panel which previously had a 1600?
I dont think I need to do much because the 1600 bolts up to the same bracket as a type IV!
I think thats because its a 73.
Joels72Lowlight wrote:Gday,
Cheers Joel.
sorry you can't use the 1800 T4 parts on the 1600 motor
Joels72Lowlight ·
Oh well. I didnt think it would.
How about the engine mounting? Here is a picture showing my 1600 engine brackets.
greedy53 ·
the 73 should be able to fit a 1800 or a 2lit they came out with a 1600 for the life of me i don't know thy
no they wont fit
Joels72Lowlight ·
What is it that wont fit?
everything
Joels72Lowlight ·
What do I have to do to fit the 1800 in my 73 Engine bay?
Carter ·
what the hell? a type 4 engine won't fit in a 73 ? Can someone exaplain this to me and Joel.... It was my unnderstanding that from August-ish 71 the engine bays were made wider to allow for the Type 4 engines...and therefore it should fit with little trouble. May need to change some mounts perhaps... but nothing drastic. I don't understand. Someone please clear it up for us?
bah dont listen to birch 😂
he right about the heads not fitting but all 72 and later kombis have engine bays that take type4 engines
some were fitted with 1600 engines (mainly panels and single cabs) and just had some really large breast plate tin like the one pictured above.
so long and short yes a type4 will fit if its after 71
u may just need to swap the input shafts if its a 1600 box as type1 engines use shorter ones
Dave butler will be able to confirm that
I was answering the origional question bout heads to 1600
yes the 73 had the larger type 4 engne bay so u can fit a Type 4 engine
Joels72Lowlight ·
Thanks guys yeah Im using an 1800 box. So all good. I didnt expect the type IV gear to fit.
Carter ·
Nice!
