Hard Brake Lines
https://forums.aussieveedubbers.com/threads/79694/hard-brake-lines
Aussie 路
Where can I get these in copper or stainless? Looking for front to back section.
hellbugged 路
local brake supplies can do them for you just take in your end squirrels......
forget copper
or VVDS have them ready to go........volksbahn were advertising them on ebay too
and don't forget to order new grommets for the bulk heads.......otherwise order a few sets of the hard lines 馃槀
Aussie 路
hellbugged wrote:local brake supplies can do them for you just takes in your end squirrels......
forget copper
and don't forget to order new grommets for the bulk heads.......otherwise oreder a few sets of the hard lines 馃槀
No-one does copper?
helbus 路
Copper does not pass ADR, as it has a higher fatigue rate than mild bundy or stainless.
Aussie 路
helbus wrote:Copper does not pass ADR, as it has a higher fatigue rate than mild bundy or stainless.
Didn't know that. Thats why I use this forum!
What would OE hard lines on an Oval come as? Mild steel? Would it be wise to paint for protection if I renew them?
helbus 路
You can get mild bundy tube as a zinc coat or an E coat. The zinc coat looks more original. The E (electro) coat is a green finish and is what newer cars for the last 20 years or so have been using. The zinc coat will protect for corrosion quite sufficiently.
STIDUB 路
Go VVDS & by the complete set, works out roughly the same as the one big line 馃檪
