Velocity Stacks
https://forums.aussieveedubbers.com/threads/79786/velocity-stacks
airkewld ·
Just wondering where I could get some ram tubes / velocity stacks to fit 50mm redline/weber throttle bodies ?
These are DCOE - reckon they would fit??
http://www.redlineauto.com.au/products/product/52845-015?category=LXHLYYXN
Hardiman Auto Supplies
9 Bullecourt Avenue
Milperra NSW 2214
Australia
coletrickle ·
Check you yellow pages for metal spinners they may have the dies to make custom ones to suit your application.I know there is a place in melbourne and all they do is ram tubes,turbo intakes etc i've used exhaust tube flared out that worked well but its not cool😂but hey i'm crazy and poor!
reub ·
Injection Perfection...
http://www.injectionperfection.com.au/component/option,com_marketplace/page,show_ad/catid,6/adid,101/Itemid,76/
colonel mustard ·
ah! so thats where the Gold ones came from!!!!!!!!
are your throttle bodies injection perfection too reub??? because you can get them from....
But add, injectors, IDA manifolds, + linkage and obvioulsy, computer... that aint cheap!
colonel mustard ·
+ injection perfection is cheaper. 🙂
airkewld ·
Thanks guys... Hopefully i can find something that will fit my TB's.
dangerous ·
Wow I did not realise you had none!
Mine made 5 more HP at the wheels just going to better ones.
Snap Crackle Bang ·
With my engineering hat on I'd say that Dave is getting less entry loss with the large smooth radius on those puppies. A correctly sized bell mouth can better than halve the losses compared to a straight inlet. (I work in industrial ventilation and noise control, its the same concepts on a larger scale.)
airkewld ·
We are just running the 6 inch k&n filters at the moment but would like a set of the race stacks for the track.. Dave is there any chance you can make me a nice set lol..
dangerous ·
Unfortunately Kris, the 13 hours on the lathe,
and 200 odd dollars worth of material,
would most likely prove to be false economy!
OLD-DOG ·
Dear Dave...just worked out how a woman can't fit in your budget.There would be too much competition
with the power bill on the lathe !!!
66deluxe ·
Here you go http://www.vwparts.net/CB7224.html just used a set of these on a bus build with 40 IDF's their good.
Damo.
airkewld ·
lol thats fine dave no worries at all im sure il come across something.. The hardest part is just finding something that will fit with the correct bolt pattern... I have the original stacks which have been machined down so that the air filters slip over the top but do not see them being efficient enough for racing.. I noticed CB performance have 6 " race stacks to fit their 48 mm throttle bodies. I assume they would bolt on but would the 2mm difference be something to worry about?.. And would shorter wider mouthed stacks be more benficial?...
dangerous ·
OLD-DOG wrote:Dear Dave...just worked out how a woman can't fit in your budget.There would be too much competition
They CAN fit in my budget,
but I just dont have the nerve to use the ones that are, "pay as you go"!!🥲😂
Kris, you may need to get something the correct size.
While a 50mm throat,(or even 45) should in theory, be more than enough for your engine,
any steps are a bit bogus.
Ultimately you are looking for a gain,
so I would have to advise making, or acquiring, the correct item,
and make sure the engine is then, not too lean after fitment, due to increase air flow.(yes, back to the dyno).
westi ·
give me a template of what the stud pattern is with the id.and i can make you a set.you just gota tell me how big you want them.
