Hi everyone,
I'm a daily lurker on here, but given I know nothing I rarely contribute, but have learnt much since I bought my first Bug nearly two years ago, so thanks everyone for the information and entertainment.
Anyway it is about time I pulled my finger out and learnt more, in the only way possible, by getting my hands dirty.
So to that end, I have acquired a stock 1600tp engine (out of Steve and Dave Carter's white 1303 (thanks Steve)), and the plan is to pull it all apart and put it back together and get it running again. The good news is if it all goes pear shaped I can afford the loss.
But, given that I'm pulling it apart, I figure I might as well make some improvements as I put it back together, and then replace the stock 1600 sitting in my car at the moment so I can have more fun. So the question for today is, what improvements would you recommend?
I don't have a budget as such, but I'd prefer not to spend the earth on this stage of her development, because I still need to save for lots of other things for her as well as a much bigger engine (or Subie transplant) in the future. For no particular reason I was thinking of aiming for less than $2k on the engine. If you think more needs to be spent, feel free to say so.
I already have a set of 36IDFs that need reconditioning and some parts to make them work properly.
Some of the things I'll need (or want) are:
- Alternator
- Manifolds
- Hex linkage kit
- Exhaust system
- Tacho (and associated stuff)
- Oil temp and pressure (including senders etc)
Those last three items I'm not counting in the $2k.
But what else would you suggest?
Should I go up in size? 1776? Higher?
Camshaft?
Crankshaft?
Ratio rockers?
Heads?
Deep Sump?
Also, given the used nature of the engine, is there anything I should definitely replace or get reconditioned / machined?
Given that I'm a engine building newbie, it needs to kept reasonably simple AND robust because once finished it will go into a car I drive a few times a week. Also because I'm such a newbie at engines, specific suggestions (what cam, what rockers, where from etc etc) would be great.
Look forward to your suggestions and appreciate your help. Once underway I'll be asking 10,000 questions as I fall into every hole there is.
Thanks & Cheers 馃槑
Craig
Craig S 路
