Lowring
https://forums.aussieveedubbers.com/threads/79821/lowring
71-BEETLE-SEDAN 路
Hey, I heard a rumour that i can lower the front of my car by removing torsion bars.
Its a 71 Standard.
I posted this on the samba but got one person saying its good and another guy saying dont do it, also i havent been on there in a while but it seems that the majority of people on it have no patience or manners. Compared to here where everone helps out no matter how dumb the question.
Okay back to the lowering. I got told by onwe guy on samba that i should remove one small one from top and bottom, would that mean top bar and bottom bar or trwo from both.
ian.mezz 路
if its a super people cut a coil off the spring on the front struts.馃お馃檯馃お
71-BEETLE-SEDAN 路
Yeah pity its not, i got a mate with an old cdore with cut springs all round. three in the back and alll you here is tyres rubbin on the wheel well
But yeah advice needed
ian.mezz 路
put a couple of bags of sand in the front ,馃お馃お
it works and sand is free.馃槀
Joel 路
its not a good method and would be illegal if it was policed
its essentially the same as cutting springs
if you want a bolt on solution get dropped spindles
if you want an adjustable solution get some adjusters welded into your beam
both are nice and safe/legal and dont effect ride quality
ian.mezz 路
Joel wrote:its not a good method and would be illegal if it was policed
Joel talking about illegal , how is your car????馃槀
71-BEETLE-SEDAN 路
Yeah thats what i thought, Im thinking of doing it for a while till i get the funds for drop spindles, i would go adjustable but i dont have another car to drive so cant have my girl off the road.
Does anyone know if fastinfatrod is on here?
Joel 路
ian.mezz wrote:Hi
modified but nice and legal thanks for asking 馃槀
71-BEETLE-SEDAN 路
I think mine maybe under the heavily modified group now.
ian.mezz 路
71-BEETLE-SEDAN wrote:I think mine maybe under the heavily modified group now.
That sounds like my super , mine is legal and insured so I can drive it to the shops and to church on Sundays.馃槀
71-BEETLE-SEDAN 路
Pretty sure if im smart to a cop and he starts lookin ill go broke
71-BEETLE-SEDAN 路
Okay back on topic which torsion bars would i remove?
greedy53 路
call george at classic he has the drop spindals for under $200.00 an easy fix and you keep the confey ride
as for torsin bars 2 top 2 bottom and 2 splines rear will give you 2.5 inches thats if your bars arn't a bit sagey already
71-BEETLE-SEDAN 路
Yeah the rear is already sagy so im gunna make it have a slightly forward slant.
Ill probably be getting enough money for spindles in around 4 weeks.
Joel 路
both you and your bug will hate removed leaves trust me on that
and with how cheap dropped spindles and adjusters are these days theres no excuse for anyone to be using that dynosaur method
71-BEETLE-SEDAN 路
Yeh i just looked at classic, are they the cheapest dop spindles?
rose 路
And you forgot to mention having your scones on the way be carefull not to spill the coffee 馃槀馃お馃槀馃お
roundtoit 路
don't you still need to narrow the beam with drop spindles or the tyres rub on the guards?
Dirtbag 路
gsa2at fitted drop spindles to his '68 semi auto and the standard wheels/tyre combo rubbed even in a straight line. They pushed the wheels out about 5/8 of an inch a side. It's now got a narrowed adjustable beam, making the drop spindles fairly unnecessary.
