Wiring a Hazard Switch in a '68 Type 1
https://forums.aussieveedubbers.com/threads/79826/wiring-a-hazard-switch-in-a-68-type-1
hulbyw ·
My bug doesn't have a hazard switch as standard, however I do have a hazard switch off a later bug.
Any suggestions as to how I can wire it to give me working hazard lights?
hulbyw ·
Any suggestions? I am guessing I may have to use another flasher relay with the hazard switch. Does that sound right?
warb ·
dunno if this helps however i used a small aftermarket pre wired hazzard setup in my 61 bus, just find a positive and hook it up to the lights, worked a treat...
pod ·
wiring diagram for 67 -70 bug
and later usa
E3 K6 hazard switch J2 Flasher can
just copy and paste, then use windows picture viewer and just enlarge it to see it better
hulbyw ·
Thanks pod, much appreciated
hulbyw wrote:My bug doesn't have a hazard switch as standard, however I do have a hazard switch off a later bug.
I haven't wired a set up from scratch for many years...
The USA wiring is Very different from to OURS
I usuallu use the 1969 wiring diagram...
PS: I never did get My hazard lights working yrt..
cheers Lee
