fish26 wrote:Interesting,
As I understand it, there are few things you need to consider before limiting the upward movement of your front end while transferring precious weight to the rear end which I assume is correctly set up, by strapping it down, because it doesn't mean that if some people are running that set up it will work for you.
In a car that runs 13-16 sec 1/4 mile you want the front end to stay loose and move up as the weight is transferred, hence 90/10 shocks and softer spring rate.
It is only when you start running 11-12 sec 1/4 mile that you want to stiffen the front end and limit its upward movement, the HP to run those times and a PROPER set up rear end will pull the front tires easy and you are limiting that pull using the strap.
Please correct me if I am wrong.
I think your right, but Sauron's car could/can run that fast.
