ok people with serious cars. What are we all using for fuel pumps. EFI turbo cars is what I am interested in.
Craig Torrens 路
Sorry carbies and normally aspirated !!
But I use a FACET pump .馃榾
amazer 路
I need fuel to spray from injectors, not dribble.
Tazz 路
I know a guy is using a nissin 260Z pump....
used to run a 6CYL EFI nissin engine....
Craig Torrens 路
Oops sorry:cry
56astro 路
*voice of Cartman*
Respect mah arthoritar!!
speedster356 路
If it a spray nozzle you want to use then try a fuel pump from a mechanical fuel injected car (I used one from a Triumph I think it was for the jetbike) as the pressures are much higher than electronic FI. Something in the order of 100psi I got I think?
Dasdubber 路
Sorry no EFI turbo here but I will be running a Holley blue with red regulator to drop the pressure down to a measly 3-4psi....just the way the dual dells like it!
Hope you find what you are after though.
Peter Leonard 路
200 bucks gets you a k2 karcher.. 1450 psi....
raahhhgghhh馃榾
1303Steve 路
Im using a VL turbo and Leighs running a NA VL, we are both using Carter lift pumps to fill our surge tanks.
1302Steve
Keith Haeusler 路
Frazier,
I got a couple sitting here in the shed, you can have one if you want. They have 1/2 inch inlet with a 3/8 outlet. Keith.
amazer 路
what sort? send me u2u? let me know when I can come and pick one up. and a reminder of directions.
