Original 12 volt crank pulley diameter??
https://forums.aussieveedubbers.com/threads/80078/original-12-volt-crank-pulley-diameter
bajachris88 ·
I bought this degree sand seal pulley many moons ago, and i suspect its a power pulley, but i have no idea. I can't remember out of the many things i ordered in my parts inventory...
How wide is the stock pulley?
I have a steel 6 volt stock crank pulley, will that be the same diameter as the 12 volt?
It won't fit though with my sand seal, but just something for me to play with none the less.
Thanks guys!
Christopher Leete.
hellbugged ·
bajachris88 wrote:I have a steel 6 volt stock crank pulley, will that be the same diameter as the 12 volt?
yes
bajachris88 ·
awesome! Thanks mate, will measure off that one 👍
Hi Chris...
most sand seals are machined to fit into the case,,,
and use a special pulley...
I see now You can buy a sand seal that fits into the case and a special pulley is again used....
so, NO seal to be used with a VW pulley....
the VW pulley is used with the oil slinger..
PS: I don't like or recommend power pulleys... LEE
PSS; many NEW alloy pulleys now need shims to make them fit????
bajachris88 ·
Thanks Lee!
Yea i got the sand seal that you tap in. Bloody genius!, and sooo easy. i got the proper alloy pulley for it and the shims. 👍 I fitted it without the shims and when torqued up, the crank locked up (eek!) i couldn't turn by hand...
I just wanted to measure up the crank pulley to make sure i didn't grab a sand seal pulley when i bought it ages ago... Cause like you and alot of wise dubbers i have heard, no one seems to approve of them, and rightly so. The vw engineers had it right the first time and don't want to break away from that.
If its a power pulley it can be someone elses problem 😀 👍
chris, youll know if its a power pulley
they noticably smaller
bout the same size as the gen pulley
speaking off does anyone know if there were other variatons on stock pulley size?
all my aus 1600 twin port pulleys are the same size but the one of dads engine which is a european 1300 twinport is about 10mm smaller
bajachris88 ·
Thanks Joel 👍 its certainly not that small.. no way. substancially bigger...
yes
NO......a 6 volt pulley is smaller and also has a different offset to a 12 volt pulley.
A 1300 12volt twinport pulley is the same as a 6volt pulley in diameter but has the correct offset (same as a 12v)
I use the 1300 TP pulley on the street as you can rev past 7000rpm without throwing a belt due to the slightly smaller size.
The largest of all pulleys is the 36hp pulley.
cheers craig that explains it
chris heres a power pulley on a mates old bug
ok so its not quite as small as a gen pulley but not far off
