DIY Immobiliser :)
https://forums.aussieveedubbers.com/threads/8012/diy-immobiliser
XXX-1.8T ·
Just a question do any fuses control ignition?
I was thinking if one of the fuses did then everytime i leave my car i can take out one of the fuses sort of like a DIY immobiliser, cos lately ive been paranoid about my beetle being left outside by herself
Costa...
[Edited on 1-7-2003 by XXX-1.8T]
Yes one of the fuses controls the ignition system.
Its usually one on the end of the fuse box depending which model you have and should be a red one.
XXX-1.8T ·
So does this mean if i take this out it wont start and nobody can take my baby
:beer
sure does
baybuscamperkid ·
😀😀😀great thinking!
Stanley ·
simple method. Do what I do . If you can't park it where you can see it pull your rotor button out and lock your lid ,easy. How many thieves carry a vw rotor button in there kit.
BiX ·
my greatest fear is getting stuff stolen from the car rather than the car itself being stolen. Like steering wheel, seats, stereo etc. just got to work out the best way to keep them safe?
Oasis ·
If you don't mind paying you can get central locking and deadlocks fitted. My car has a Brant system fitted and is apparently very hard to get into...
Adam_C ·
Big Fucking dog!!!
RSPCA wont like it but the car is safe
JOKING!
jimmy1812 ·
Hey, i have a decent sound setup in my car, 2 x 6"x9" kennys, 2 x 6" kennys, an Alpine 3 cd stacker, and a boss audio 1000w amp, so keeping my equipment in my car, and not in a thieves hand is a priority haha. I've Bolted down my speaker tray, making it harder and more time consuming to remove speakers if they tried, i've also clamped down my deck (works nicely, thieves tried to take it when they broke in, left empty handed). and i have my amp under the speaker tray. Just add an extra bolt here and there, but not dodgy looking, it worked for me, and im still pumping the tunes out of the beetle!
P.S. The rear luggage compartment in beetles really gets good bass thru it 🙂 get 6 x 9's!! :P
oval TOFU ·
jimmy1812 wrote:P.S. The rear luggage compartment in beetles really gets good bass thru it 🙂 get 6 x 9's!! :P
I know that! i had 2 X 4 way Kennies and they sounded like an 8" sub!
yum yum bubble tofu
schultzbug ·
schultzbug ·
fuz ·
while taking the rotor button is fun and will work.. its a little impractical.. and stealing fuses is just going to weaken your box, i wired a external fuse from the box and a switch which i concealed inside the ashtray all the wiring is in the front and covered by the carpet.. so basically its a killswitch without running it to the engine and its invisible unless you know that your ashtray is the immobiliser.. has saved my baby a few times.. though it wont save your quarter window when they get in :o/
I have a screecher alarm kit from DSE that I am going to use in My beetle. when mounted inside the car, when it goes off, it is too loud to stay inside the car.... I have always thought that car alarms should be inside the car to make it uncomfortable as possible to the thieves.
You can always hide a switch etc so the ignition won't work... or even wire it to the parking light switch, so the parkers have to be on to start the engine....
another thing I have placed in a Beetle was a 6.3mm stereo socket. to start the car, a 6.3mm male plug had to be inserted .. or it could be used in the opposite way if wired differently...
With a type 3 Variant I owned for many years, I installed a key switch on the car, & if the doors were opened with the switch on... the alarm sounded.... so I didn't have to lock the car.. just switch on the key switch.
cheers and never give a crook an even chance...
RSI ·
Shultzbug
the alternator shouldn't have any problem with supplying power.
fuz ·
depending on the year the 'generator' is a 55amp and thats sufficient for that stereo.. just not that stereo 2 full beam lights and 4 spotlights, interior neons and a police siren.. much to my dissapointment :P
A beetle DC generator only puts out 30 amperes. a nominal output of around 360 watts at 12 volts.
an AC Alternator puts out 50 amperes.
a nominal output of around 600 watts at 12 volts.
As You can see, there is a large difference between the output of the Generator and the output of the Alternator. What would You rather have ??
11CAB ·
If you take out the fuse, what stops someone just using the next fuse along??
I was thinking of fitting a kill switch to the +ve coil wire, that way if someone tries to start it or hotwire it, the engine will crank but not start.....most people will just think there is a problem with the car and move on.....was thinking of using a push on/push off button inside a cigarette lighter since i dont smoke.....nothing like a kill switch in plain view.....😀
Black_math ·
A big ass steering wheel lock and some of these handy little things
http://www.stickdeath.com/2003auto.html
Enjoy😀:thumb
Peter Leonard ·
HAAHHAHAHAHAH
i want it!
specially like the paralysis mode, and the door slammer. not tooo sure about the missile defence option, and i already have the remote control function 😀
Black_math ·
Hehe you gotta love it 😀 and i thin keverybody deserves a missile:P
[Edited on 30/9/2003 by Black_math]
helterskelter400 ·
the old stickmeister,
wondered how long it'd take for stick to cross vw path.
i got my warning outthere
stickdeath equipped
Black_math ·
Hehe ,man thats soo kool u get it off the website? i think i might order one😀
helterskelter400 ·
naa
typed up, printed out & photocopied onto some stikky transparency hangin at work.
also got...
Black_math ·
oh thats shiny im gonna have to buy some of that sticker stuff:thumb😀
Boozer ·
yeah 11cab i've done that. putting a kill switch onto the coil and hiding it somewhere is really good. It hasn't been tested yet as no one's broken in to my bug yet but several times i've forgotten to turn it off and sat there with the engine turning over wondering, "why the F##K won't it start!", untill i realise that i've left it on and manage to just start it with a almost flat battery...😀😀 actually I did it today *again* in a shopping center carpark...very embarrasing...
Black_math ·
Yeah boozer its really hidden in the ********* of your bug😀
Boozer ·
you'd better not tell anyone or i'll kick your a$$ boy!😠😠:cussing:cussing
Black_math ·
Who cares anyway , who wold want to steal it:P
T25Turbo ·
A few thoughts:
a) The alarm inside the car is a good deterrent, but I would need a clean pair of shorts if it went off accidentally, akin to the good old air-horn-while-your-head-is-under-the-bonnet-trick! i.e. not worth it.
b) this should be a sacred topic, only discussed out in the open in rainstorms.
Don't tell everyone your tricks!!
You may become paranoid next time your precious gets broken into.
You never know who might be reading this!!
c) I had a 15" sub in the back of my L bug, behind the seat. Actually I still have the box if anyone is interested.
To say it pumped was a major understatement. On of my mates nicknamed the car "The finger of God"
2180 with 48's, 4000rpm in 4th off the clock etc. Aah Memories!
SKEWtYpe3 ·
love stickdeath
used to play it in class at tafe after 3 hours off spent in the pub 🙂
