bajachris88 wrote:The generator is already 12V.
They have inbuilt regulators don't they?
use the same stand? Generator fan fits just the same...? same belt? differences? Same wiring?
Thanks fellas!
CHris 馃榾
A Generator stand is different to an alternator stand Chris...
an alternator fan belt is a different size . 11.3 x 912mm
You could grind a Generator stand to fit an alternator..
very easy if you had both sitting side by side...
If the alternator only has two connections...
[internal regulator]
a screw connection - main power to the battery..
and a push on connector which goes to the dash lamp...
PS: the alternator is earthed thru the stand and strap etc...
