As posted, Dave has asked me to find out, what size are early bug trans/engine mounts???
Sides ·
Jezebel has an early style front trans mount, and the studs on the pan are M10... so 10mm diameter, and the nut needs a 17mm spanner to turn em.
What's he up to with an early style trans mount ???
colonel mustard ·
umm.... its a bust trans with a beetle nose cone and rejs bell housing... Im not sure.
STIDUB ·
deciding if 4 gearbox case studs on the bellhousing end will be sufficient or if i should use the 2 lower engine studs aswell,
gearbox studs are only 7mm so i figured the standard banana mount size studs would be something useful to compare to
thanks for posting, i didnt have the laptop at work today, too busy doing uh.... work 😁
Sides ·
Ahh, well if it's the rear box mounts you're talkin about, that's a slightly different story (from the 'early' part of the question, I'd assumed front mount)
But, anyway:
- "banana mounts" to trans are M8... so 8 mm diameter (and yeah - there's 4 of 'em)
- engine to trans bolts are M10... so 10mm diameter if you were somehow going to build a mount around that
STIDUB ·
yep yep, sorry i didnt explain what i needed to know very clearly to mustard, was in a lil rush, lots of things going thru the grey matter & all that, comes with juggling real work & bug work i guess
