Hello all,
New to vw's. Just wondering which engine the 2276cc big bore kit fits to?
Cheers.
hobbit ·
https://forums.aussieveedubbers.com/threads/80190/2276-big-bore-kit
hobbit ·
sander288 ·
Camo ·
Sorry, but it's not. Its 84 stroke with 94mm bore is a 2332.sander288 wrote:82mm stroke, 84mm is 2332 or something
hobbit ·
Camo ·
also a lot of head work and carburation requiredand you're right, there's a bit of machining required
VW Donks 101:hobbit wrote:The kit I've found is a 94 x 82 piston kit and you're right, there's a bit of machining required. The problem is not sure which engine would be a good starting point, or the most capable. Has anyone done this mod before or seen it done? Will this kit fit on a 1600 as well as a 1800? Are the bottom ends the same?
I'm new to these engine's so any help would be greatly appreciated.
thanks..
hobbit ·
