My vintage VW has been giving me a bit of trouble lately. The suspension at the front is creaky - I had it lowered by AVW Performance Centre with anti-sway bars 5 years ago.
Not exactly sure whats wrong with it. I had it checked by another VW mechanic who said it was a lack of lube - but after two lube jobs in 1 year - the problem is still creaky. Each time I drive over a bump or turn - I hear something creaking away.
I'm just wondering whether I should send it to AVWPC or send it to Peddlers Suspension.
Comments anyone?
AVWPC. definately not pedders. What year is it, if early, king and link pin style, the need grease every 5000km and if left for a long period without service can block the grease channels to the king pins. Simple job to raise the car off the ground and grease the 8 grease points, even adjust the link pins, it's not rocket science, and a good idea as this should be done at the same service interval.
Peders sell and install shock absorbers
Send to a VW person
Bizarre wrote:Peders sell and install shock absorbers
Send to a VW person
And not even good ones😂
Blue65 ·
Its a mid- 1960s model. I had it sitting idle for over 3 years from 2004 - 2005, and 2007 when I went overseas for work. What exactly blocks the grease channels to the king pins? Is it the old hardened grease? I assume that AVWPC would have a better idea of suspension issues with VWs as they deal with them on a regular basis yeah?
HappyDaze ·
If the suspension checks out OK, have a good look at the frame-head. They tend to crack after a while, but can be re-welded successfully.
Cheers, Greg
Blue65 wrote:What exactly blocks the grease channels to the king pins? Is it the old hardened grease?
Yep, and metal filings because it wasn't lubed!!
ancientbugger ·
If it's a creaking noise it could just be a wheel bearing.
Blue65 ·
Great news! Mick from Australian VW Performance Centre fixed the problem within the hour!!!! Woohoo!!!!
And it was relatively cheap!!! woohoo x10.
Mick found that the screws holding the front end (if I remember correctly) were loose - they were tighten and now all the creaky and squeaky sounds are all gone. And the steering is now firm and tight.
